Mechanism Assembly
Hi -- I am wondering if any of you have experienced a problem with too many bodies when you make a Mechanism. I have a 3-body assembly which contains one 3-piece assembly. That 3-piece assembly shows properly as a single body, but when I add another assembly, the program counts that assembly as 2 bodies, regardless of the number of parts in that assembly and won't run because "one body has zero mass". I am aware that the units have to be the same. I can get around the problem by adding parts to the problem assembly AFTER I have the simple 1-piece working, which is awkward and hopefully unnecessary.
Any thoughts? --- thanks
