Mechanism - Crank, rod & piston assembly
Hi all, I posted this on mcadcentral this morning but thought I'd try here aswell. This is my first post so please be gentle..... Sorry for the length of the post but I just wanted to describe how I've set up the assembly....... I'm currently working in Pro/E Mechanism with a flat plane V8 crank, rod and piston assembly. Basically I want to be able to create measures which will give me results for the 5 main bearing loads but I'm struggling. I have set up Mechanism to analyse the system over one engine cycle (2 crank revolutions) and have applied combustion loads to the top of each piston as a function of the "crank_angle" measure I have set up. I have applied "connection reaction" measures to the Mechanism joints between piston and rod little end and between crankpin and rod big end. I get good results from these measures. The forces are of the correct order and they vary as expected over the engine cycle. I have an excel spreadsheet I wrote a few years ago for a similar engine which I'm using as a reference to verify the results. However, I'm struggling with the crank main bearing loads. I have assembled 5 'rings' as "ground" parts to the assembly to represent the main bearings. These are assembled to a skelton part within the assembly via a crank centrline axis and dutum planes to position axially. I have then assembled the crank using the same skeleton crank centreline axis as a pin joint and have used a datum plane from the same skeleton to specify the translation. My servo motor to turn the crank assembly is applied to this pin joint. Just for starters I have further constrained the crank by adding another pin joint at main bearing 3. I've done this by using the axis within the main bearing part and the local axis created through the 3rd main within the crank part. I then add the measure and run the analysis. I do get a load at main bearing 3 but its a constant 75N which just isn't right. Adding another pin joint to the crank produces 2 measures of a constant 50N which is also wrong. Just writing this has made me think that maybe I should assemble the crank using 5 pin joints made to the 5 main bearing parts and leave out the initial constraint to the skeleton part. I'm not sure how applying my servo to one of these joints will affect the results but I'm not in position to test this theory at the moment. If anyone has any ideas I'd be very grateful. Surely someone out there has attempted to set this kind of thing up in Mechanism before. Many thanks in advance, Adam
