Repeat Region in WF4 m220
pperry
If I create a repeat region to show quantity and Part Name:
3 11111_12345678-003
1 11111_12345678-008
1 11111_12345678-007
1 11111_12345678-006
1 11111_12345678-005
1 11111_12345678-004
1 11111_12345678-002
1 11111_12345678-001
I have tried to write several different relations to strip the 11111_ from assembly member name. I am using the extract function but cannot seem to get the relation right.
final_name = extract("asm_mbr_name",6,10)
gives me the table:
10 (and no member name). I am using asm.mbr.user_defined as final_name to generate table. I had one relation that returned 10 12345678-003 but have lost that relation. I know this is a simple fix.
TIA.
Patrick Perry BAE systems
MartinHanak
(To:pperry)
Patrick,
you have to follow this procedure (see uploaded data):
1.]
Create Repeat Region and put &asm.mbr.name into its column.
2.]
Define relation.
final_name=extract(asm_mbr_name,7,6)
These two steps are saved in 11111_drw.drw.4 drawing.
3.]
Replace &asm.mbr.name with &rpt.rel.final_name.
This third step is saved in 11111_drw.drw.5 drawing.
Martin Hanak
Martin Hanák
6 REPLIES 6
MartinHanak
(To:pperry)
Patrick,
you have to define Relation in Repeat Region and then put &rpt.rel.final_name into Repeat Region cell.
I uploaded test data...
Martin Hanak
Martin Hanák
i have done that and the table becomes one line. One of the issues I have is my relation does not want to accept asm_member_name as a valid attribue. If I use the final_name = asm_mbr_name the relations show and error and will not move forward. The error indicates tha asm_mbr_name (or asm.mbr.name) is an invalid symbol.
MartinHanak
(To:pperry)
Patrick,
you can find the answer inside my test files (created in WF4). Download repeat_region.zip and do some investigation:
> check Repeat Region properties
> check Repeat Region relations
Martin Hanak
Martin Hanák
Martin,
The problem is we do not want to show the asm_mbr_name. If I create a relation final_name=extract(asm_mbr_name,7,6) without the column with asm_mbr_name, the relation is invalid. I could reduce the column with to 1 character and you would not see the as_mbr_name. Is there a way to hide the column completely?
MartinHanak
(To:pperry)
Patrick,
1.]
2.]
Define relation.
3.]
Martin Hanak
Martin Hanák
That did it. I was trying to create the table with the relation in one step. That realy seems strange to me. Thanks for all your help.
Patrick Perry
