Maybe I am not using the round feature properly... But If have a single round feature that creates 7 rounds on a part. I later redefine a feature, causing the round to fail. I go into redefine, to remove the failed rounds.
Say there are 3 failed references (with the red dot) that I need to remove. I am unable to shift select the 3 failed features and delete at once. I also cant select one, and hit the 'DELETE' key to remove it.
I have to, one by one, select the feature, right click, select Delete. Thats NINE clicks for a function that should only take one. Surely, I'm doing something wrong, or I don't fully understand how to use the round function.
Someone help, my mouse hand is killing me.
TIA,
David
Hi Terry,
Long time no see. Haven't been to a conference since 2010 and have changed jobs meantime.
In line with your reply I just replied to a 2014 reply from Michael Loccasio(Sp) about the orange dot edges for rounds and how I would like to be able to accept the Creo algorithm chosen edges so that they are no longer orange. And yes being able to do this singly or as a total lot would be great. RMB anyone?
Regards, Brent
Is there a vote for it?
For complex rounds i prefer 7 features instead of 1 feature with 7 sets.
I find simple changing references if they fails. That's my opinion but it depends on part.
