Rubik's Cube, A 3-D mechanical puzzle....
  • December 12, 2011
  • 2 replies
  • 26908 views
do u ever tried mechanism for it in Creo.. if not try it see attechment and hv fun ^^)
Message was edited by: DalbeerSinghSohal
Geez Dalbeer... You're trying to give people heart palpitations, aren't you?
I'm not sure I have the brain power to figure out another mind-bender. I'm still working on the pattern relations slides!
hahhahaha no thats is not my intenitons clearly.., it just came into my mind. i'm still trying to do it but no success so far. if there is a way to do it we will figure it out..
Yeah I thought about this one during my drive home (40 minutes) and I have a few ideas. I'm sure I can get one face to turn... the problem is when cubes need to switch faces. The best I could come up with was something tying the mechanism to coordinate system (possibly a spherical one if that's possible)... I just don't know.
I'll play with it and share the results!
Hi all
Here is my animation of Rubik's Cube
Have a nice day.
Vladimir
PS: For quick animation you can use many planar constraints and snapshots
great animantion Valdimar , but i m talking about pro/mechneism how can we do the same thing that u did in amination???
Hi Dalbeer
Do you need create same assembly like org. Rubik's Cube (the real one) - create main body with many Pin constraints combine with planar constraints.
Good luck
Vladimir
