SUMMARY - can Pro/PROGRAM change which instance is assembled?
lylebeidler
Thanks to all who replied.
The answer is yes, it can do that.
Jason Clark supplied this sample code to show how:
RELATIONS
IF TANK_SIZE == "3000" & PRESSURE == "175"
FRONT_HEAD = "14031844"
REAR_HEAD = "14031836"
ENDIF
(similar relations redacted)
END RELATIONS
ADD PART (FRONT_HEAD)
INTERNAL COMPONENT ID 94
END ADD
IF TANK_SIZE == "6000"
ADD PART (SHELL4)
INTERNAL COMPONENT ID 5571
PARENTS = 5568(#12)
END ADD
ADD PART (SHELL5)
INTERNAL COMPONENT ID 5574
PARENTS = 5571(#13)
END ADD
END IF
ADD PART (REAR_HEAD)
INTERNAL COMPONENT ID 95
END ADD
Thanks also to Kevin Alexander for this:
There is a function called ?lookup_inst? that does exactly this ? from
Pro/Help:
To Replace Family Table?Driven Components
You can automatically replace family table?driven components according to
design criteria by using the lookup_inst function. With this function, you
can search a component family table to find an instance that fits the values
of the search parameters. If the lookup function does not find a match, it
returns the name of the generic.
The format for lookup_inst is:
lookup_inst ("generic_name", match_mode, Òparam_name_1Ó, match_value_1,
Òparam_name_2Ó, match_value_2,...)
where
* generic name?Name of the generic model with a .prt
or .asm extension
* match_mode?One of the following values:
o ?1 (find closest instance with param values less than or equal
to supplied values)
o 0 (find instance with param values that match supplied values
exactly)
o 1 (find closest instance with param values greater than or
equal to supplied values)
* param_name_1?Family table parameter name
* match_value_1?Value to match against
See Also
About
<file: c:\ptc\wildfire4\html\usascii\proe\program\about_replacing_componen<br="/>ts_in_assembly_designs.htm> Replacing Components in Assembly Designs
Example:
<file: c:\ptc\wildfire4\html\usascii\proe\program\example_replacing_family<br="/>_table_driven_components.htm> Replacing Family Table-Driven Components
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
