Hello PTC community,
I'm using Creo Parametric 9.0.4.0 and would like to perform simulations. Apparently, the Simulate is grayed out but Flow Analysis is not. Is this licensing issue or something else?
SR
Resolved.
The issue was that the Simulate extension was not installed the first time. Cool thing about Creo is that you can install additional extensions without going through full reinstall.
Resolved.
