Folks
i am trying to move a knob using the slot connection but i get these errors:
1. Servo motor on slot in the assembly model cant be satisfied
2. The rigid body 1 connected by Connection_7 in the assembly cant be properly oriented
3. The following kinematic loop cant be closed: Ground-body1-Ground
I dont understand the last error as it shouldnt apply to my problem
thanks
I try to fix the model to resolve the issue. You have to refine it to suit your design.
thanks. too bad i cant open in creo 7.0
