Welding console Constraint
JohnWick
I would like to calculate the welding bracket correctly. But I have not yet found the right approach.
Or should I simplify the model first?
Load: 4kN
ptc2788381_3-1719907366690.pngptc2788381_4-1719907556945.pngptc2788381_5-1719907600797.png
JohnWick
(To:skunks)
Thank you for your help. I didn't know that the rigid connection was defined in the part.  👌
13 REPLIES 13
my example to start with
JohnWick
(To:skunks)
Why did you delete the radius here?
JohnWick
(To:JohnWick)
I have started another experiment.
Here in the radius I have increased mechanical stresses.
precise bearings are important here
JohnWick
(To:skunks)
Hello, what do you mean by "precise bearings are important here"?
This console is only plugged in. The bore has a small oversize.
example:
can the axle turn?
JohnWick
(To:skunks)
Yes, the axle can turn.
OK, the axle can turn, what combination of materials is this?
JohnWick
(To:skunks)
Machine base: cast iron
here my example
JohnWick
(To:skunks)
Hi @JohnWick,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
Community Moderator
Catalina
PTC Community Moderator
