partial multi radius on an edge
opavot
2-Explorer
Hello everybody I have to creat a variable radius on an egde as following PNT8 Radius=0 PNT6 Radius=1.5 PNT4 Radius=4.1 PNT2 Radius=8.3 PNT9 Radius=0 I don't know how to creat this , I used the round function but it don't work . If one of you have the solution , many thank to help me Olivier
DELETEME
(To:opavot)
It sounds like far too radical a radii change for what you're doing. You CAN set the option to create the radius as a surface, and see why it won't solidify. I have a feeling that the radii are too large and cannot be created. Good luck.
