"Glenn Dutcher" wrote:
We are have the same problems here and we have gone back to 7.0. I have a call in on your #1 " In CADprocess, when a drawing is converted to 2d, it will not load up on another computer running 7.1 Foundation. It gives a "This file is corrupted"
"Russell Trim" wrote:
Hi Tim, This makes interesting reading regarding the problems your having with the latest upgrade to 7.1. We are currently using v7.0 but have had annoying issues relating to hanging in the middle of a full zoom command, raster editing and no undo, as well as save issues with a tilda~ in front of pathname. We have had no resolution to any of our queries and were hoping they would be resolved in the next upgrade. This dosn't look like it is going to be the case. I reckon we will stick to v7.0 until we get a better view on what is happening with Isodraw. thanks Russ Trim
anonymous wrote:
Selecting items using the shift key to add items to selection. As you select extra items, some of those already selected look like they de-select, though they are in fact still selected - it seems to be a display problem.
"Christopher Dabrowski" wrote:
Our company switched For instance when I bring in ProE data(WF3) capscrews, o-rings, washers etc. will be 2-3X larger then necessary. Another thing I am seeing is difficulty in finding a happy medium when projecting to 2D. Either the settings are leaving too much detail in or the objects come in with distortions in bezier paths. Of course if I eliminate the bezier paths that helps but then I have more work/cleanup of line entities to keep file size down.
