Application toolbar in Arbortext 8.3.0
amyhill_serco
After installing Arbortext on a new laptop, some things aren't working how they should and I don't know why. I have allowed the application toolbar and turned it on. The change markup dropdown isn't showing the other tags allowed at the point of insertion. I'm trying to change a table to a chart. When I put my cursor to the right of the table start tag, the change markup dropdown should show chart as an option but it's not there. The only option on the dropdown is table.
I don't remember doing anything on the old laptop to make this work, it just worked. Is there a setting that I'm missing?
Thanks!
Amy Hill
9 REPLIES 9
Go to tools, preferences, and make sure that show full menus is selected.
Bryon
amyhill_serco
(To:bfriesen)
Yup, full menus is on.
Do you have a customized application? Did you upgrade from an earlier version of Arbortext editor.  We use the TIA application with Editor 8.1.1.1 and I do not see chart as an option.
amyhill_serco
(To:bfriesen)
It was not an upgrade, this was a new installation.
I'm editing tech manuals for the US Navy. The doctype is 970930na_cdata.dtd. Tables and charts are both allowed at this particular point of insertion.
Dear Customer,
Could you please share if this is the only option are you expecting should be shown there? Or you are noticing any other changes?
Could you please also share a snapshot showing this expected requirement?
Manpreet Singh
amyhill_serco
(To:manpsingh)
Both table and chart should be shown there as both are allowed at the point of insertion. Tables get counted in the numbering stream while charts do not. So when I come to a table that should be a chart, I used to have the option change it via the dropdown in the application toolbar.
The attached screenshot shows the application toolbar with the dropdown for changing markup circled in red. There should be two options on the dropdown to the right, table and chart. Right now it just says table.
The application toolbar is set as allowed in the DCF. I have also configured the toolbar so that hitting the bold/italics/underline buttons will insert the appropriate tag. So that part works fine, it's the change markup dropdown that does not work.
Dear Customer,
Thanks for your response. When I am checking at my end, I also see only the 'Table' option under the drop-down list. I have attached the screenshot for your reference. I am not sure how were seeing 'Chart' option as well under the drop-down list in previous releases.
Please let me know if I am not looking at the right spot which you are expecting to check.
Here 'Table' tag is inserted under the 'P' tag that I have looked at my end.
Have you customized your previous version of Arbortext Editor to get 'Chart' option as well?
Manpreet Singh
amyhill_serco
(To:manpsingh)
It doesn't look like you are in the same doctype as there is no "p" element in this doctype. I'm using the US Navy's docnavseac2 doctype and at the specific location in my document, tables and charts are both allowed. They are essentially the same thing but one gets counted in the numbering scheme and the other does not.
This used to work correctly on another laptop that I used previously. I did not do anything special on that laptop to make it work, it just worked out of the box. It's basically the "change markup" function of Arbortext, but in a drop down on the application toolbar.
Dear Customer,
I understand that you're using a different type of document. If you are able to reproduce this by using any of the OOTB document, then it can help me identifying things accordingly. If you're still not sure, I would recommend you raise a Technical Support case about this use case and an engineer will assist you accordingly. Thanks.
Manpreet Singh
