Is anyone using Isodraw 7.3 to highlight a line with a mouseover or click? If so what might that technique be?
I grouped a set of lines in a schematic, applied a hotspot to the line, and when I enable the hotspots, and view within IsoDraw using IsoView I don't get much in the way of an indication. Lets say one clicks on the line, it flashes briefly and that's it.
Animation doesn't seem to apply because I am not moviing or rotating the line. Also, the imported CAD dwg file does not have any ids for the lines that are imported. Should there be?
Is there any way to get the line to highlight and stay highlighed?
My thought is to export this to WebCGM later.
Ok I have an answer, self taught.
