How can I execute a custom function before publishing the document using a Styler stylesheet?
PV_12583628
We would like to perform some custom action (copying files from remote server) before the publishing action is performed from the "Publish" dialog box. Ho can we embed/ perform our custom actins before the publishing action takes place.
Hi @PV_12583628,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
You can use the composition framework hook for this. Define a function in ACL that does what you need to have happen, and attach it as a hook function. This is described in the help center:
https://support.ptc.com/help/arbortext/r8.2.3.0/en/#page/PE%2Fpeprog%2Fpe3102.html
https://support.ptc.com/help/arbortext/r8.2.3.0/en/index.html#page/Program/acl_ref/help22635.html
