How to know the last page of a title in a TOC?
  • February 11, 2014
  • 1881 views
Hi all,
In a TOC, is showed the first page where each title starts. I need to know the last page where the content of this title appears. Someone knows how can I do it?
Best answer by SimonTaylor
There isn't any information by default, but you could add some if you like.
Use something like
formatting.currentXMLNode.setUserString("lastPage", formatting.currentPage.pageNumber);
in the 'onExit' source for your title (better still in the onExit code of a property set associated with the title).
You can then use XPath in your ToC to retrieve that information using something like:
formatting.evaluateXPath('x3b2:get-userData("lastPage", self::refNode())');
Use that in the generated ToC elements somewhere...
setUserString() is a DOM method to add private info onto a node. The get-userData() XPath extension function is an XPath equivalent. self::refNode() is a custom location passed by nodes which are augmented onto a DOM when adding a TOC.
Simon
rboneti1-VisitorAuthor
In App, there's any information about this? (last page, or current page)
Use something like
Simon
Thanks for help Simon!
Using your help, I get the number of the last page, and the first too.
The first page, I got on the "onEnter" and the last page I got on the "onExit".
Now, I need to use this both informations together, to write a stream like this:
for(var i = firstPage;i<=lastPage;i++)
stream.write( "Intro ...." + i + "\n");
I can do it with xpath or something?
