IsoDraw is under the Arbortext brand, which is part of PTC (think GM > Chevy > Cobalt).
In regards to the commandline, are you trying to start IsoDraw from a command line, or are you trying to run a command line from IsoDraw?
Here is what you are looking for. Note that you may need to change the name of your exe file based on your version.
The question is typically:
I need to start a batch process from the commandline. Is that possible using the macro language or the Batch Tool? How?
Our answer should be like:
Yes, it is possible to either invoke macros from the commandline or to control the Batch Tool by doing so.
1.) how to start a macro from the commandline
Any macro can get invoked by the use of this commandline syntax:
IsoDraw7.exe" {<illustration_file> [-macro <"macroname">]}
For IsoDraw7 use the following syntax:
C:
CD ptc
CD Program
IsoDraw7.exe C:\Convert\m_test.iso -macro"Debug"
Using that syntax, you might call IsoDraw and open any particular illustration to apply some changes, defined in a macro, to it (like deleting unused pens) and after that save the results.
2.) how to start the Batch Tool from the commandline
The Batch Tool is implemented as a plugin to IsoDraw. These plugins are located in the extensions folder and it is possible to send commandline-events to them by the use of this syntax:
IsoDraw.exe -ext <plugin_name> <arguments>
The argument string will be sent directly to the plugin, which processes it then. The arguments-string of the Batch Tool is build like this:
-s "srcPath" quoted path of source folder
-d "dstPath" quoted path destination folder
-f format format options (see kIsoFormat_Standard)
[-c] scale scale (optional, default 100%)
[-m] "macro" quoted path marco to be excuted on each illustration (optional)
Where the possible format identifiers are:
Standard 0
Iso0400 1
Iso0300 2
Iso0260 3
EPSF 4
AI_1_1 5
AI_88 6
IGES 7
DXF 8
HPGL 9
CGM 10
PICT 11
TIFF 12
BMP 13
PCX 14
CALSRaster 15
TEXT 16
INT 17
MIF 18
Iso0500 19
Iso0500Packed 20
DWG 21
SVG 22
JPEG 23
PNG 24
WMF 25
Iso0600 26
Iso0600Packed 27
As a result, the commandline to initiate an export of a source folder 'd:\sources\dxf' into a destination folder 'e:\destination\cgm' and a call of a macro 'CleanupPens' for each file, will need to look like:
IsoDraw6.exe -ext batch6.isp -s"D:\sources" -d"e\destination\cgm" -f10 -m"cleanuppens"
