Linking Java and Arbortext
pzorrilla
Hello gurus!
Today I'm having a problem with some of my java methods, I created an
Arbortext button which calls through aDocument doc = Acl.getDOMDocument("0");
getElementsByTagName("Sect1");
childsByTag.getLength());
for(int i=0; i < childsByTag.getLength(); i++){
this.getNodeContent(node,");
childByTag node that I have found in my first oid_find_childrenoid,root_children_arr,"SectX") < in java and get the
elements of the root_children_arr, in order to process them in a
recursive function.
Please if anybody could help me I would be pretty grateful. As always I
really appreciate your time, help and support.
Paulette
You could either iterate through the DOM itself, or just use an XPath to
get a set of applicable nodes.
For XPath, you'll also need to add some helper functions, as XPath support
isn't native, but can be exposed through ACL.
See example:
trick I would think.
On Wed, Feb 27, 2013 at 12:30 PM, Paulette Zorrilla <
paulette.zorrilla@oracle.com> wrote:
> Hello gurus!
> Arbortext button which calls through a dlgitem_add_callback command a
> java method, this method will ex...
Thank you! It works now using Ac.lfun(...) 🙂
