In my bookmap I have different layers (part/chapter/topicref), if I use profiling on one layer, then profiling on a child layer of this layer does not work.
For example: I have 3 products A, B and C
Chapter1 (profiled for B and C)
- Topicref1 (profiled for B)
- Topicref2 (profiled for C)
- Topicref3 (not profiled)
Now if I publish with profile A, nothing will show (as expected).
But if I publish with profile B (or C) then the 3 topicref will appear when I'm only expecting 2 (Topicref1 and Topicref3 for B).
Am I missing something?
Which version of Editor are you using? Can you send a screen shot of how the profiles look in the Column view. We ran into the issue of cascading attributes. Search cascade.
So what this means is that if chap 1 is parent profiled for B and C, Its property's are given to the children automictically.
Bryon
Bryon
Hello Bryon,
It seems that I was indeed missing something. This cascade article is exactly what I needed, each topicref/chapter was set to merge by default and switching to nomerge finally gives me the result I was expecting.
I have had this problem for years on different Editor versions and have been using a workaround ever since.
Thank you so much for your help!
Glad it worked for you. I don't remember when it changed my guess is 8.0 when Dita 1.2 was added.
Bryon
