Publishing error messages
KW_11025334
7-Bedrock
</Record><Record date="Fri Feb 21 13:44:38 2025" millis="1740167078"
severity="fatal" suppress="0">
<Level>FATAL ERROR</Level><Message>Operation terminated.</Message>
</Record>
How do you relate this to a particular line or section of your document?
Detailed errors mention line numbers. Is there a way to see line numbers in Arbortext Editor?
I am using version 8.2.
Accepted solution
7 REPLIES 7
Take a look:
Does this happen with every publish or just once?
Bryon
Thanks for your reply. I have corrected the problem. In doing a cut and paste from another document, I did not properly format a section.
BTW, Editor error messages could be more detailed, to point to where the problem is.
I agree that the error messages are not always. helpful in trying to figure out what the issue is. Another tool you could try is the completeness check, found under the tools menu. It should flag improper structure in your document.
Bryon
Thanks, will do.
Hi @KW_11025334,
Anurag
Accepted solution
