Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Define your conditions, and then go to the Tags tab in Styler, where you can add attributes to the HTML output. I think that should get you where you want to go.
