interupts, or events
ptc-4624896
is it posible to integrate interupts in IsoDraw macros? the problem is when macro is runing it is imposible to zoom in or zoom out, and some time later I get white screen.
wait mouseClick is not working as I want, it wait for mouse click, but as I said it is not posible to zoom.
Did you try "Sleep"? This should resume the macro execution after
the given number of milliseconds without blocking the UI in the meantime.
E.g. for 5 seconds:
SLEEP 5000
If the redraw doesn't work in this time, you should try to put the redraw
command (with a shorter sleep period) into a loop - e.g. for 50 times repeat
sleep 100.
Sleep seems not working too, still you can't zoom, and after some time IsoDraw gets "Not responding"
