length of a string in points APP
  • April 23, 2018
  • 3657 views
How can I get the length of a string in points? (not the number of letters)
Florin
Best answer by GarethOakes
You're meant to run this during formatting so it picks up the current formatting properties. I haven't tested what it does outside of formatting context, it will pickup some defaults, but you can use PIs in the text string I believe (or wrap it in a styleSave(), styleChange(), and styleRestore()).
Here are a couple of options to measure a string:
APP code: <?show $^(#"Testing")>
JS code: var l = fLength(); l.text = 'Testing'; application.alert(l.makeAbsolute());
otudor1-VisitorAuthor
Hi Gareth,
for application.alert(l.makeAbsolute()); statement I get a message of "69.5666mm" and for
application.alert("length : " + l.makeAbsolute()); statement I get a message of "695666" only.
Do you know why? and in what unit is the second message? micrometers?
Florin
