length of a string in points APP
  • April 23, 2018
  • 3657 views
How can I get the length of a string in points? (not the number of letters)
Florin
Best answer by GarethOakes
You're meant to run this during formatting so it picks up the current formatting properties. I haven't tested what it does outside of formatting context, it will pickup some defaults, but you can use PIs in the text string I believe (or wrap it in a styleSave(), styleChange(), and styleRestore()).
Here are a couple of options to measure a string:
APP code: <?show $^(#"Testing")>
JS code: var l = fLength(); l.text = 'Testing'; application.alert(l.makeAbsolute());
otudor1-VisitorAuthor
Hi Gareth,
for application.alert(l.makeAbsolute()); statement I get a message of "69.5666mm" and for
application.alert("length : " + l.makeAbsolute()); statement I get a message of "695666" only.
Do you know why? and in what unit is the second message? micrometers?
Florin
One last question. Is this solution taking in consideration the font size and family which have been set prior measuring the string?
Thank you!
Florin
