text element without backfill color
ptc-4464050
Hi, first of all: This forum is a great source for me to use and understand IsoDraws macro language.
Great. Never the less i have a question to the „element.text.backfill_color“
My goal is to tell a text element to use no (no) backfill color.
(note that backfill color is not the color of the written text itself but the color behind the text)
Now i looked in the newest macro reference and found the way to set the color of the background of a text element as ColorSpec („element.text.backfill_color“ )
But how can i tell the text element to use no backfill at all?
I tried several ways but my macro knowledge is not that big (yet).
I also tried to set „$ISO_NOFILL“ as a color
(since it is written in the reference - but it didn’t work out)
Might be super easy but I can’t find it.
Any idea is very much appreciated.
Hi.
If you like to know how to set a certain value to an element property, try the other way round.
E.g., to find out how the backfill color of an element with _no_ backfill is defined, select such
a text element and try:
MESSAGE activeDoc.firstSelectedElement.text.backfill_color
in this case it is going to return
{Ref "$ISO_NOFILL" 100}
(Which is indeed is a color spec. and not a plain color.)
Thus the following will remove the backfill color from a selected element:
activeDoc.firstSelectedElement.text.backfill_color = '{Ref "$ISO_NOFILL" 100}'
(Please note that this uses single quotes.)
Hi.
thats great.
Thank you so much - this way it works out for me.
Nicely explained as well.
I appreciate the hint with the MESSAGE and will try to use this in the future.
Thanks again
(still wonder why it didn't work out for me in the first place -
might have been the missing single quotes you mentioned)
