Oct 3, 2017 11:53 AM UTC
Creating BOM table in Creo Drawing involving sub assemblies components
I have an assembly model that involves 2 sub-assemblies. When I add automatic BOM table the subassemblies appears in the table, while I need to add a BOM table to the assembly drawing covering all components ( main and sub-assembly).  Can anyone have a solution (BOM of all components and not subassembly names)?
Oct 10, 2017 7:57 AM UTC
you can apply filter on your repeat region. Something like
&asm.mbr.type == PART
StephenW
Oct 3, 2017 12:00 PM UTC
Your BOM table is set to be "FLAT". You can change to be "RECURSIVE"
Go to the table tab, repeat region, select attributes, select your table, select recursive then done.
Oct 9, 2017 10:59 PM UTC
Thanks Stephen
I followed that process and now I have all the parts and also assemblies name on the table, how I can remove the assembly items from the BOM table?
Jun 29, 2020 2:21 PM UTC
@Deepakjohsh wrote:
HI Martin,
In continuation, is it possible to show a specific component of a sub-assembly in the BOM table of the main assembly by using Relations/ rules in Filter.
For Example:
In the below Assembly structure, Main Assembly is made of Sub-Assy1 and Sub-Assy2
If any of these Sub-Assemblies contain a pipe, I need that to be shown in the BOM table of MAIN Assembly
Is it possible to do this with help of relations/Rules in the repeat region?
 Assembly_treeAssembly_tree
MAIN ASSEMBLY BOM TABLE:
Bom_TableBom_Table
Thank you!
Deepak
you can define 2 repeat regions, first one for top level components and second one for pipes.
