How to disable Open Missing Reference Model Pop-up
mtonsager
Creo 2.0- When I open a local copy of an old assembly, there are missing merged parts that cause a warning "Reference model ### is not in session.  Please select it." along with a pop-up window to select the missing .prt.  I am using the assembly for analysis only and don't need the base parts so I end up selecting Cancel on a whole bunch of these base parts.  Is there a way to disable this pop-up?
Matt
2 REPLIES 2
you can check setting of following config.pro options
RETRIEVE_DATA_SHARING_REF_PARTS
RETRIEVE_MERGE_REF_PARTS
I am not sure if this can resolve your problem.
Martin Hanák
Hi configuration edditor add this command RETRIEVE_DATA_SHARING_REF_PARTS for this value is Ignore_missing. then you will get reference pop_up window
