Hello everyone,
I've been reading discussions here for some time now and really trying to solve this but with no luck so far.
There are so many links and topics here that are very similar to what i need, but none of them really helps in getting me any closer to solution.
What do I need to achieve?
I need to report different parts in a assembly as one within a drawing report table.
I have made a table driven by user defined parameter &position, following by repeat quantity: &rpt_qty, after that user defined parameter: &description, then &mass=pro_mp_mass and finally I've made a relation driven parameter for total mass per reported component: &total_mass_per_component=rpt_qty*mass
So far I've been led to think that what I am trying to do is impossible due to fact that reported parameters (above mentioned) within a table row for each component are not the same- thus they can not be shown as one- even though they have the same position param- Please confirm if this is correct?
if not, please advise and help in anyway you can.
Much appreciated.
MB
P.S
Same parameters within table are:
&position
&description
ones that varies are:
&description
&mass
&mass
