Is there a way to save a part or assembly (and maintain parameters) in Creo 2 that wildfire 4 can open and use/edit the full geometry or assembly?
Not really. There is an application called Granite (from PTC) that is suppose to be for this but it is not a one-for-one open... it is more of an import converter.
This is a common questions. Look at this conversation it should answer your question.
