Hey
Is there a way to prevent a drawing from being created if the person is using a PRT file. All of our drawing are supposed to be of an ASM(even if it's only one PRT file). Some people follow the guideline but others don't. What happens is, more often than not those PRT drawings need changed to an ASM post implementation and the drawing changes are much easier when the drawing model is already assembly file. Any suggestions on how to force Pro/E to require the use of an ASM file before allowing the user to create the drawing file?
Thank you.
TW
First of all why would you ever do that? 🙂
You might be able to use ModelCheck Rules somehow?
