We need to expose the installed Codebeamer from outside of system , from any Public network so that we can integrate codebeamer with any Application like Git, Jira, Windchill etc.
We had a similar requirement to make Codebeamer 3.0.0.2 accessible from public networks so that it can integrate with tools like Git, Jira, Windchill, etc. Here's what worked for us:
Reverse Proxy Setup:
We used Nginx on a public-facing VM to route traffic to the internal Codebeamer instance running on port 8080.
DNS & Static IP:
Assigned a public static IP and mapped a DNS (e.g., cb.company.com) to it.
HTTPS Configuration:
Enabled SSL using Let’s Encrypt for secure access over HTTPS.
Firewall Rules:
Opened only port 443 (HTTPS) to the world. All other ports are blocked.
Security Measures:
Restricted access via IP allow-list (optional).
Enforced authentication and strong password policy.
Enabled logging and monitoring at the proxy layer.
Once exposed, we successfully connected Codebeamer with external tools via APIs and webhooks.
Hi @TD_725989,
Anurag
