Following situation:
Tracker A has a field that references items from tracker B.
An item of tracker A (A*) is created. The field is set to point to several items of tracker B (B*1, B*2, B*3)
The History of item A* now shows that the reference field changed value from nothing to (B*1, B*2, B*3).
Now delete item B*2
Now the History of item A* now shows that the reference field changed value from nothing to (B*1, B*3). (The same version as before)
Expectation: We need the reference for the above scenario
Hi @VS_10892000
By deleting B*2, you are, in essence, making it as if it never existed, so the history is correct. If you want to keep the reference to B*2, you should close the tracker rather than delete it. Deleting removes the tracker and all references from the database and should not be used when the history of the item needs to be maintained.
Hi @VS_10892000,
It looks like you have a response from a community member. If it helped you solve your question please mark the
reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
