How to address tracker key in interwiki stereotype
DS_10843371
6-Contributor
I would like to define an interwiki stereotype in the application configuration resulting from this interwiki link
[<<itemnamerevision5>>|ISSUE:1234]
 the following format:
Requirement name (Rev0, REQ-1234)
Application configuration:
"itemnamerevision5" : {
   "link" : {
      "text" : "${name} (Rev${customField[5]}, ${trackerKey}-${id})"
   "popup" : {
      "text" : "Description: ${description}"
The variable ${trackerKey} does not work asexpected. I also tried several other variable names without success. How can I address the tracker key?
CB version: 2.1.0.6
Thank you in advance.
Have you tried tracker.key? It seems to work for me.
            "myitem" : {
                "link" : {
                    "text" : "${summary} ${tracker.key} ${id}"
                "popup" : {
                    "text" : "${interwikiLink} Status: ${status}; Description: ${description}"
            "myitem" : {
                "link" : {
                "popup" : {
DS_10843371
6-Contributor
(To:PolarBear)
Hi @PolarBear,
that is exactly what I was looking for. Thank you.
