Problem after converting the database from MySQL to Posgres
VM_11608121
2-Explorer
We are currently using CB-2.1.0.5 with a MySQL database.
We want to migrate to PostgreSQL and are using the Migrator Tool via Docker Images to convert the database.
The conversion completes without any issues, but after updating the database in the configuration file and restarting CB, logging in either results in a blank screen or a 404 error.
What could be causing this issue?
Hi @VM_11608121,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
The logs should be a good place to start. This support article mentions where the logs should be located. It is still relevant for your version of Codebeamer.
https://www.ptc.com/en/support/article/CS409610?source=search
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
