Where to find Project Groups in Codebeamer X UI - Codebeamer 3.1
AW_10741129
I am trying to figure out where to find the Project Groups section in the Codebeamer X UI. An older wiki page for Codebeamer X (https://support.ptc.com/help/codebeamer/r3.0/ko/index.html#page/codebeamer/cbx_user_guide/cbx_projects/cbx_11126.html#wwID0ETSGKB) says that user groups can be added. But the link for how to do that is a circular reference to its own parent page which doesn't contain the information.
Are project groups still a thing in Codebeamer X? If yes, where do I find them? If no, what has replaced this functionality?
alfonso_c
(To:AW_10741129)
Hello @AW_10741129 , the Project Groups feature is not available on the Codebeamer X user interface, a similar feature that you could possibly use instead is Project Categories.
We will update the documentation.
Hi @AW_10741129
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
Hi @AW_10741129
The project groups are managed in the project group tab on the project browser screen.
I also noticed that you mentioned user groups; I'm not sure if that was a typo. However, user groups are an instance-level security model, which is managed in the System Administration tab.
Brian Kampling | Software / Systems Engineering Consultant - Source Allies
AW_10741129
(To:BKampling_SAI)
Hi @BKampling_SAI,
Thanks for the reply, yes user groups was a typo, I meant to say Project Groups. I do know where to locate the project groups in the standard Codebeamer UI, which is what it looks like your screenshot shows. I am looking for where that same feature is in the new Codebeamer X UI.
Best,
Andrew
alfonso_c
(To:AW_10741129)
