(Codebeamer 2.2.0.0)
I cannot find a way to generate report with data from review-hub.
I would like to monitor:
how to call review data in the "new report" page ?
Thanks !
Hi @MB_12823193
If you want to see a list of ongoing reviews and their status, you can see that on the Review Hub dashboard. The Reports tab can only generate tracker item reports/traceability reports based on data on the tracker. If you could provide some additional context around the questions you are trying to answer with these reports, I might be better able to help you design a report.
Hi @MB_12823193
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Hi @MB_12823193
Hi @BKampling_SAI ,
Thanks for you reply. I understand there is no obvious way to get review status with the report tab.
Actually, I wanted to play with it and for example get a report of my current open review with the signed/not signed status.
BR
Michael
