Can project baselines be available as templates?
  • August 27, 2025
  • 2 replies
  • 408 views
Pretty self-explanatory! Though I don't think it's the case, I wanted to ask around if anyone can confirm that project baselines are not able to templates.
Thanks!
Best answer by BKampling_SAI
@MT_12158826, you are correct. Baselines are used to capture a snapshot of the project at a specific point in time for historical purposes. If you need to create a template from a baseline, you can use the REQIF export of the desired baseline, reimport it as a new project, and make that project available as a template. Please let me know if you would like additional guidance on how to proceed or if you have any further questions.
Catalina
Community Moderator
September 2, 2025
Hi @MT_12158826,
I wanted to see if you got the help you needed. It seems that @BKampling_SAI's reply is a solution.
If so, please mark it as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Moderator
