Creo won't start with WorkerDaemon as a service
BenLoosli
When we switched from WF4 to Creo last week, we also upgraded the settings for the publishing machine and put a local copy of Creo on it. Went through the Adapter.pvi and the Workder.rcp files and updated them to work with Creo2. We were already running the CreoView Adapters, so the only change was Creo2 from WF4. When we start the GS Worker as a service creo will not launch. The GS Worker is calling WorkerDaemon.exe. If I open a command prompt and run WorkerDaemon manually, then I can get Creo2 to start from the Worker Agent Administration window.
Has anyone else had this issue with Creo2 or CreoView? PTC seems stumped on my open call.
Going to cross post this to other groups for better coverage.
Can you be more specific as to what was done, when you mentioned :
"Went through the Adapter.pvi and the Workder.rcp files and updated them
to work with Creo2" ?
What is the current adapter version being used ? I guess you have to refer
to CreoView adapter compatibility matrix and check if its supported with
the version of Windchill & Creo.
-Vaibhav
On Fri, Aug 29, 2014 at 11:45 PM, Ben Loosli <->
> on my open call.
Here are some helpful articles:
BenLoosli
(To:BenLoosli)
This issue has never been resolved, even with a rehosting to different servers,
I do not have this issue with my other 2 Windchill systems where we publish on the Windchill server and not a separate workstation. When this system gets upgraded o Windchill 11.1 in December, I will move the CreoView publishing to the server and hope it works there.
