I have a spline in sketch mode where I need to add points. For the life of me I can't figure out how to add a few points.
I know I have done this in the past but with earlier versions. I'm on Creo 2 now.
Should be simple. Maybe it's a Friday thing.
Thanks for any help.
Select spline.
Right click, select modify.
At some location on the spline, right click and "Add point".
Select spline.
That was simple. Thanks a bunch
