We’re aware of an issue preventing community login. Our team is actively working on a fix and we’ll share updates as soon as possible.
CGM files - Need Help
teslacad
Hello all,
I have a customer that needs me to open a .CGM (Computer Graphics Metafile) file in ProE WF 4, make some changes and then exporting it out as a .CGM.
The problem I am having is that ProE does not see the file or does not recognize it.
Does anyone have any experience with this problem?
Many Thanks,
TCW
grocha
(To:teslacad)
This old format each year has fewer and fewer CAD software supporting it, maybe this can help you:
<u>http://www.sysdev.com/sdi_cad_translate.html</u>
There is a trial if this kind of work is not constant.
Warm Regards
Guilherme Rocha - Tech Support Consultant
PLM Solutions do Brasil
“A goal without a plan is just a wish.”
grocha
(To:teslacad)
PRO|E has this option when opening a file, you've said that PRO|E was not able to see the file, nowthat's weird, try to check the extension of the file and use the option "All files"in the "Open" dialog box.
but depending which software generated the CGM it can generate issues regarding different sizes from the original and imported/exported files in/from PRO|E, there is a document from PTC about it:
<h1>Solution Details - TPI 109316</h1>
Solution Actions
Solution109316 TypeTPICreated Date26-Jul-2001Last Updated26-Jul-2001
TitleCGM Files Exported from Pro/­ENGINEER and Imported Into Other Software Packages Are Not The Correct Size.­DetailsAdditional Information
Description
If ProE can not see the file, then my guess is that is has spaces in the
filename or other special characters. Rename and try again.
/Bjarne
Tesla CAD <->
01-06-2010 16:32
Please respond to
Tesla CAD <->
To
cc
Subject
[proecad] - CGM files - Need Help
Hello all,
as a .CGM.
recognize it.
Many Thanks,
TCW
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailling list Manage your subscription
Use of this email content is governed by the terms of service at:
Greetings
If ProE can not see the file, then my guess is that is has spaces in the filename or other special characters. Rename and try again.
/Bjarne
And in some places (e.g. WF4 Manufacturing Postprocessing) spaces in folder names somewhere up the tree of the working directory cause silent refusal to work. It made me smile (grimace perhaps) when I read the comment, in the thread on Pro|E on Macs, about PTC working so closely with Microsoft. A Vista like file open dialog and a ribbon does not make a Windows application :=)
John Prentice
