Change outer diameter in cylinder with curved slot
ccruz
I have done everything I could in order to change the OD=1.600 to OD=1.770 in this model, but every time I try, I loss the slots and curves.
I would like to have the same exact slots shapes and measurements with an OD=1.770.
Please be kind enough to help!
CC
manjunathrv
(To:ccruz)
See attached model that i changed but at Dia 1.78.
Also you may need to fix a round that failed.
Looks good Manjunath RV, thanks! May I ask how you did it?
manjunathrv
(To:ccruz)
You need to go to Edit Definition for the import feature and enter into the Import Data Doctor.
then select the outer surfaces and select Convert to Cylinder:
and enter appropriate value to match your requirement, click Done and complete:
