Variable shell
  • May 26, 2016
  • 2666 views
I need to create a PET bottle with variable wall thickness.
Is there any way where I could maintain variable wall thickness.
NOTE: the share of the bottle is not circular, the base is elliptical.
    Yes.
    You can use the Non default thickness option to select the specific surfaces with their own thickness:
    amitshah1-VisitorAuthor
    But it creates a step in the model !
    Do you have any image for reference
    No. It will not create steps.see attached.
