Circle Centerline
wfalco
Circle Centerline
I am sure this has been asked to death.
And I should know the answer to this by now.
But I'm gonna ask again.
Is there a way to get a circle centerline to show in Creo 3?
I have been using cosmetics and hiding on layers.
WayneF
StephenW
(To:wfalco)
Yes...IF...
If you use an AXIS pattern to create your slots AND you have the drawing setup option radial_pattern_axis_circle turned on
And I added an axis to the slot sketch
StephenW
(To:wfalco)
Yes...IF...
wfalco
(To:StephenW)
Stephen...NICE. I tried on new geometry. Works as advertised. Unfortunately I am documenting someone else's model and they used 1 feature to extrude. I don't know if I want to redo the geometry. But I will keep this in my bag of tricks. Thanks!!!
Wayne
MartinHanak
(To:wfalco)
I think you can cheat little bit ... to add the pattern of datum axis or datum points to get circle centerline.
MH
Martin Hanák
wfalco
(To:MartinHanak)
This was my first thought. It did not work. I also wanted to use Flexible Modeling. However - that is NOT available in sheet metal.
wfalco
(To:wfalco)
I ended up redoing as patterns. Worked out nice. Thanks Stephen.
