Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
hi. I was wondering if it is possible to convert the 3D files to a .fla extension (flash). The general idee is to put the files on the website, but in 3D flash. Thanks in advance. Bert
