Looking to try to create a wavy washer and a washer with radial teeth cut into it? How would I go about doing this?
Thanks. Jon.
I tried that one, but if you look at an actual wavy washer, it's not the same. The coils actually have to stack (like the pic I posted), crest to crest, for it to work. There's one small issue I'd like to tweak to make it perfect, but I never got around to it after making it initially.
Lot of interesting formulae there though, thanks for re-linking it for the others!
One more. This is using a trajpar, your favorite, Frank. This one maps the section correctly and is super-simple for a wave washer. See the latest comment for the trajpar statements:
