Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Yu can use View>Display Settings>Visibilities, but it is not like CATIA V5. It is clipping the model parallel to screen. It is useless. Mustafa TURGUT TURKEY
This is the single most usefull presentation function when we do design reviews. We generally take the model out to eDrawings and then use the functionality there. Does anyone from PTC actually visit these forums? Surely a user friendly dynamic sectioning tool is not too much to ask for?
I used to use Solidworks, and the dynamic sectioning was excellent. You could just swipe a plane through the model and it would display the section in real time. Realy need one in ProE, I have to edit the dimension on my section plane and update for each veiw I want, rubbish.
