Tools/Progam/Edit Program (to change) or Show Program (to view only)
I believe they are statement groups bounded by INPUT and END INPUT that gather data. Just delete them or comment them out using "/*"
Also, I believe you can define a parameter and use it in an IF/END IF block in the input section to allow controlling for prompting. For example:
INPUT
IF RUN_PROGRAM == TRUE
parameters for input
ENDIF
END INPUT
Yes, the "switch" described by David is probably the very best choice for a few reasons.
