Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Is there an easy way to cap off holes in ProE 2.0? I’m needing to do this, so I can run simulations in CFdesign. Or is there a better way of doing it? If anyone has any other helpful tips and hints it would be much appreciated.
Suppress is like temporarily removing. If you really want that but with a cap, u need to create a surface. One option is to do a sketch at the plane where u want it to be closed. then fill that sketch with surface (Select the sketch and go to Edit -> Fill). Does that serve ur purpose ? Regards Joe
