How to cap a hole easily
ptc-2046590
Is there an easy way to cap off holes in ProE 2.0? I’m needing to do this, so I can run simulations in CFdesign. Or is there a better way of doing it? If anyone has any other helpful tips and hints it would be much appreciated.
Supress them if possible.
what does that acutually do, as it doesn't give a good discrition in the help section
just tried that and it just hides the holes and doen't end cup (or fill them in)
Suppress is like temporarily removing. If you really want that but with a cap, u need to create a surface. One option is to do a sketch at the plane where u want it to be closed. then fill that sketch with surface (Select the sketch and go to Edit -> Fill). Does that serve ur purpose ? Regards Joe
