How do I install the Creo 2.0 help files locally on my users' computers. Where do I find them? Are they a separate install? Thanks!
Yes, help files are a separate installation. You will need to either download them, or install from CD (if you have one).
Greg,
to enable Creo 2.0 to show context help by pressing F1 key, you need to link Creo 2.0 with HelpCenter.
Martin Hanak
I am not sure that the environment variables are needed in the .psf files - I have not put them in and Help Centre starts up OK with an F1 in Creo.
Gary,
you are right. PTC installer writes information about HelpCenter loadpoint into Windows registry and Creo is able to read this info.
Martin Hanak
This information IS needed though if you run the help from a non-standard or shared location (like a mapped network drive).
