I have a problem, because my thesis supervisor uses Creo Elements/Pro 5.0 and I need to work on some files from his computer.
As I see, there is only Creo Parametric 3.0/2.0 or 1.0 avaible for student to download, and they are not compatible.. Where can I get Creo Elements/Pro 5.0 from?
And he has commercial version. Is there any way to work on his files using student version?
Oskar,
Commercial and Student versions produce incompatible data files. This is the base of your problem !
Martin Hanak
Thank you Martin for your reply.
So I guess I'll have to build this models by myself from the begining...
Anyway, is anywhere the Creo Elements/Pro 5.0 student version available to download?
Oskar,
if you do not need feature based model, then you can ask your supervisor to export models into STEP or IGES format and import these files on your workstation.
Ask - question "How to downalod Creo Elements/Pro 5.0 student version ".
Martin Hanak
